Date/Time: Fri, 26 Apr 2024 17:56:29 +0000
drawing a rectangle on a chart that extends right
View Count: 287
[2023-01-20 15:50:25] |
Jimmy K - Posts: 10 |
How do I draw a rectangle on a chart that extends right. Also, How then do I have the rectangle appear on another chart automatically Ive been looking through the documentation to no avail Thanks for any help |
[2023-01-20 17:05:19] |
John - SC Support - Posts: 31153 |
Use the Extending Rectangle tool. Refer to the information here: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle How then do I have the rectangle appear on another chart automatically
Refer to the documentation at the following link for how to do this: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
