Date/Time: Fri, 03 May 2024 00:28:53 +0000
data bubbles on chart
View Count: 444
[2023-01-16 18:18:04] |
User510097 - Posts: 4 |
I'm trying to create a data box on my chart of the NVOL-NYSE which has the ratio of advances to declines, which I believe the symbol for is ADR-NYSE. How do I go about creating this? I believe I've attached an example of what I'm trying to do, with red arrows pointing to what I'm trying to create. Thanks for your help.
Attachment Deleted. Data Bubbles.png / V - Attached On 2023-01-16 18:12:43 UTC - Size: 8.23 KB - 103 views |
[2023-01-16 20:24:08] |
John - SC Support - Posts: 31334 |
If you are trying to display the data from the ADR-NYSE, then you would use the Text Display for Study from Chart. Refer to the following: Text Display For Study from Chart Otherwise, if this is just text information you are displaying, then you would use the Stationary Text drawing tool. Refer to the following: Chart Drawing Tools: Type Text | Stationary Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
