Date/Time: Sat, 04 May 2024 00:39:06 +0000
Add volume on number bars
View Count: 308
[2023-01-14 20:10:05] |
OriolCasas - Posts: 155 |
Hello, I am curious on how on this picture (@smashelito from Twitter) programmed the volume indicator above the number bars (the yellow rectangle), see picture attached. How could I do the same on my charts? Thank you |
ES Volume.png / V - Attached On 2023-01-14 20:00:35 UTC - Size: 236.86 KB - 112 views |
[2023-01-16 15:43:19] |
John - SC Support - Posts: 31362 |
It's just a matter of setting the appropriate Region for the studies. For example, put the Volume study in Region 2 and the Numbers Bars Calculated Values in Region 3. Refer to the following: Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-16 15:58:53] |
I tried that, but it doesn't look quite the same. First of all, I would like to remove the title of region ยบ, 2 and 3, where it says: - Delta (No) Study subgraph.... - Volume Volume... Then: There is an significant space between the volume and the number bars indicator. How can I change that? Thank you |
ES Footprint.png / V - Attached On 2023-01-16 15:54:59 UTC - Size: 192 KB - 71 views Attachment Deleted. |
[2023-01-16 18:53:47] |
To remove the region data line, which will also remove the space, set the option under Chart >> Chart Settings >> Regions >> Region Number x to Hidden. Refer to the following: Chart Settings: Region Data Lines (List) (Chart >> Chart Settings >> Regions >> Region Data Line menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
