Date/Time: Sat, 04 May 2024 04:25:44 +0000
Logon disabled
View Count: 205
[2023-01-04 17:22:48] |
User543454 - Posts: 2 |
I received a connection error message from service: CQG WebAPI / Logon unsuccessful. Server message: Your logon is disabled. Please advise how to enable logon. |
[2023-01-05 16:06:29] |
John - SC Support - Posts: 31362 |
You need to ask your broker about this, as the message is from CQG and indicates that your broker has disabled your CQG login.
[2023-01-05 16:23:38] |
Sierra_Chart Engineering - Posts: 14207 |
In the meantime: To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-05 16:23:46
