Date/Time: Fri, 26 Apr 2024 00:56:51 +0000
Max Rithmic Direct Connections = 3?
View Count: 279
[2023-01-01 22:07:03] |
ProfitableTrader - Posts: 22 |
My service package # is 10 (Integrated Standard) It looks like the max Max Rithmic Direct Connections from a single computer is 3. If using a second system to connect to additional Rithmic connections, what is the total Rithmic direct connection limit? |
[2023-01-01 23:30:20] |
Sierra_Chart Engineering - Posts: 14092 |
No that is not correct. The 3 refers to the number of computers you can use Sierra Chart on at the same time. Rithmic will only allow a single connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-02 01:11:47] |
I'm referring to three unique Rithmic connections on three separate sierra chart processes running on the same computer. It seems like the adding a 4th connection results in delayed data. My question is whether the data will still be delayed for the 4th/5th unique Rithmic connections if running on a second computer. All am interested is the DOM data not being delayed for each Rithmic connection. Thanks! |
[2023-01-03 18:44:22] |
John - SC Support - Posts: 31131 |
Refer to the information for Connections for the Denali Exchange Data Feed at the following link: Denali Exchange Data Feed: Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
