Date/Time: Sat, 17 Jan 2026 00:43:54 +0000
Historical data
View Count: 667
| [2023-01-01 11:23:09] |
| User633898 - Posts: 28 |
Hi, The default value of days to load in my chart setting is 4380 days. However, I actually can load the historical data up to 2021 Jan for daily and weekly chart. Can you please advise how to get it fixed? Thanks |
| [2023-01-01 18:19:40] |
| Sierra_Chart Engineering - Posts: 22419 |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-04 17:34:03] |
https://www.sierrachart.com/image.php?Image=1672853566353.png Hi, here is the chart concerned. Thanks |
| [2023-01-05 16:08:30] |
| John - SC Support - Posts: 44021 |
You need to use the Continuous Futures Contract option. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-01-23 09:38:22] |
Hi, I am currently subscribed to Integrated Standard service package 10 and Denali CME Can you please advise what do I need to subscribe if I want additional real time data feed for DAX and HSI. Thanks |
| [2023-01-23 15:39:43] |
| SC Support - Posts: 2044 |
Hi Alex, for DAX Data you can activate EUREX (EOBI) Exchange that you want Real-time Data for, you can do that via #3 here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliEUREX With regard to HSI, that is available via the Sierra Chart Exchange Data Feed: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges Set-up instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions |
