Date/Time: Fri, 03 May 2024 15:43:50 +0000
Have trading DOM + order entry - with touchscreen functionality (on 20" touchscreen monitor)?
View Count: 1385
[2014-05-31 15:18:17] |
User59863 - Posts: 36 |
Talking about fully functionally trading DOM + order entry - with touchscreen functionality, optimized for desktops If not, how easy is it to port it over? Of course, buttons need to be bigger (Buy at bid, sell at offer, flatten, reverse, hot keys etc) + usability needs to improved, as not using mouse |
[2014-05-31 21:37:26] |
This is currently supported. You can use the Sierra Chart Trade DOM with a touchscreen. It works just fine. We use a touchscreen and those buttons are large enough. You can also increase the DPI setting on your computer to enlarge the buttons. When using a touchscreen make sure Global Settings >> Chart Trade Settings >>Use Click, Release, Click Method to Adjust Orders is disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-10 02:54:24] |
Futures Operator - Posts: 239 |
^Is there a problem using Click-Release-Click to adjust orders, that it need to be disabled for touch screens? This method seems to work better for my setup.
[2014-08-10 03:29:05] |
It is perfectly fine to set that setting as works best for you. There is no problem either way.
