Date/Time: Fri, 03 May 2024 14:12:05 +0000
About the data
View Count: 261
[2022-12-28 17:06:35] |
Forward - Posts: 62 |
Hello, i would like to receive the CME e mini data + Market Stat + Indexes Nasdaq for non-professional. Now i am doing a little confusion with the different pack. Which pack of data need to take for see them ? Thank you |
[2022-12-28 18:54:56] |
John - SC Support - Posts: 31336 |
For the CME E-Mini: You need to use the Denali Exchange Data Feed. Follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the Market Statistics: These are included as part of any active package. You do not need to do anything special to get this data. For the NASDAQ Indices: If you really want the NASDAQ Indices (and not the NASDAQ TotalView stock data) then you need to use the Sierra Chart Exchange Data Feed and activate the NASDAQ Indices exchange. Follow the setup instructions at the following link: Sierra Chart Exchange Data Feed: Setup Instructions ---- If, for the NASDAQ Indices, you are really wanting the NASDAQ TotalView data for U.S. Stock data, then this is also part of the Denali Exchange Data Feed. Refer to the Setup Instructions for this at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Or, if for the NASDAQ Indices, you are really wanting the NASDAQ Indices Futures, then that is part of the CME Group and is traded on the CME exchange, the same as the E-Mini S&P 500. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-29 10:25:28] |
Hello John, thank you for your answer. My problem is that i am using to study Sierra in SCData( all data ) mode. The CME is in late of 10 minutes, ok But the NQ Index is in late of about 1 week. I want to see the NQ Index at the same time ( 10 minutes in late ) of the CME. If i rent the data can continue to use them in SCData mode ? My problem is that i don't want use any broker account to do these studies. Thank you again. |
[2022-12-29 17:05:16] |
The only data for which you need a broker is the CME Group data (ES). The Index data is going to be delayed data unless you get the real-time data. We do not have an option for this data to be Delayed Streaming like the data from the Denali Exchange Data Feed. If you want to get the NASDAQ Indices data in real-time, then follow the Setup Instructions at the following link: Sierra Chart Exchange Data Feed: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-30 04:24:40] |
Sierra_Chart Engineering - Posts: 14197 |
You can look at NQ futures instead of the NASDAQ 100 index. You will find the symbol in File >> Find Symbol >> Futures-CME .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-30 04:24:59
