Date/Time: Mon, 06 May 2024 09:48:04 +0000
Pre-Market data for US stocks
View Count: 579
[2022-12-09 20:32:41] |
User691322 - Posts: 7 |
How can I display Pre-Market data for US stocks with my current plan
[2022-12-09 21:30:21] |
John - SC Support - Posts: 31379 |
If you do not need the real-time data then you can use our Delayed Streaming Data to get the information from our NASDAQ TotalView exchange. All you need to do is to go to File >> Find Symbol and there are some instruments listed under the NASDAQ TotalView section, but you can just type in the name of the stock, you just have to add the suffix '-NQTV' (no quotes) in order to specify that you want the data from our NASDAQ TotalView exchange. For instance, you would enter IBM-NQTV not just IBM. Once you open a chart, you will want to go to Chart >> Chart Settings >> Session Times and setup the Session Times as you want them. Otherwise, if you want real-time data, then you will need to change to one of our Integrated packages and then activate the NASDAQ TotalView exchange. Refer to the following for the Integrated Packages: Description of Service Packages and Pricing: Integrated Packages And refer to the Setup Instructions for the NASDAQ TotalView exchange here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-27 15:03:17] |
I just need the historical intraday data at the end of the day. Was there a problem yesterday either on your side or on my side which gave the error?
[2023-04-27 15:29:51] |
There was no problem. What are your Session Times set to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-27 15:46:51] |
Session Start Time: 00:00:01 Session End Time: 14:59:59 Use Evening Session: Yes Evening Start Time: 15:00:00 Evening End Time: 08:29:59 Chart Data Type (List): Intraday Chart Time Zone (List): Use Global TIme zone |
[2023-04-27 15:57:27] |
The Daily chart updated fine The issue was with the intraday updates. |
[2023-04-27 17:43:39] |
Your Session Times are overlapping which could be the source of your problem. Set them as follows: Session Start Time: 08:30:00 Session End Time: 14:59:59 Use Evening Session: Yes Evening Start Time: 15:00:00 Evening End Time: 08:29:59 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-27 18:10:36] |
Got it - last question -- this setting you recommend with capture all the overnite and premarket prices right?
[2023-04-27 21:03:44] |
Yes, these session times cover the full 24 hours of trading.
