Date/Time: Mon, 29 Apr 2024 09:34:50 +0000
same cht book, same CL chart setup with 2 different feeds
View Count: 318
[2022-11-21 14:49:08] |
User61576 - Posts: 418 |
SC team pls advice on the attached screenshot on the right, sub instance of my main SC connected to Denali, as you can see the CL didn't roll on the left, a separate installation of SC connected to the simulated feed (though data is Denali as well) and CL contract did roll what is correct? |
Screenshot_9.jpg / V - Attached On 2022-11-21 14:48:55 UTC - Size: 340.87 KB - 52 views |
[2022-11-21 15:35:36] |
Sierra_Chart Engineering - Posts: 14126 |
You will have to manually perform a rollover: Changing to a New Futures Contract Month It will not happen automatically based upon the Continuous Contract setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-21 16:14:42] |
well, this is the solution though I don't understand: 1. why it worked on 1 Denali but didn't work on the other Denali 2. why it didn't work in the first place same as it works for CME symbol rollover |
[2022-11-22 00:33:41] |
1. Check the settings in each installation for Chart >> Chart Settings >> Symbol >> Automatically Rollover Futures Symbol. Refer to the following: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) 2. There are other items that can affect when the rollover occurs that could be set differently. Again, refer to the information in the above section that has links to those items. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-22 07:16:01] |
1. as you can see from the attached screenshot in the first post, the "Chart >> Chart Settings >> Symbol >> Automatically Rollover Futures Symbol" is the same. 2. i read here: Changing to a New Futures Contract Month and here Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) and here General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) and could not find the setting "Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume" CME assets' rollover is set the same in the "Chart >> Chart Settings >> Symbol >> Automatically Rollover Futures Symbol" and it does roll. can it be b/c this is CL which is monthly? |
Screenshot_10.jpg / V - Attached On 2022-11-22 07:14:06 UTC - Size: 147.68 KB - 50 views Screenshot_11.jpg / V - Attached On 2022-11-22 07:14:11 UTC - Size: 165.47 KB - 54 views |
[2022-11-22 16:50:01] |
The setting for "Detect Rollover of Current Futures Contracts Symbols Based on Real Time Volume" is in the settings windows as defined by the information in parentheses for the option. So it is located at "Global Settings >> General Settings >> Charts >> Symbol". Select the "Global Settings" menu and select the "General Settings" entry to open the General Settings window. Select the "Charts" page on that window and then scroll down (or view down) to the Symbol section on the page. The option is within that section on that page. -- In the end, we do not know one rolled and one did not. We do not see a reason for this to have occurred, but you have the information on what to do if it occurs again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-22 17:11:21] |
it was set to "no" on both SC installs. i updated to yes and hope it will not happen next roll also this doesn't explain why cme symbols roll do work as expected |
