Date/Time: Fri, 26 Apr 2024 10:02:09 +0000
Connect AMP Futures through CQG-Denali
View Count: 276
[2022-11-21 14:02:52] |
OriolCasas - Posts: 155 |
Hello, I was set up to use Denali from AMP Futures. I connected to Sierra chart through DTS CQG web api. I want to use Denali data feed. And I don't know if I am using CQG now, or Denali. How can I check that? Thank you |
[2022-11-21 14:36:56] |
Sierra_Chart Engineering - Posts: 14092 |
You will be using both. You will be using CQG for order routing and the Denali Data Feed for Market data. Instructions: CQG Trading Platform Service: Setup Instructions And: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Also you are not fully set up to use the Denali Data Feed. We will have someone help you with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-21 14:37:26
