Date/Time: Wed, 08 May 2024 10:29:00 +0000
Sierra Freezing when switching time frames
View Count: 215
[2022-11-21 09:24:06] |
BHowellNZ - Posts: 19 |
Hi all I am having an issue with my Sierra, has only started in the last week and is most prevalent in a couple of symbols. It is however intermittent When I switch from 5min candle to 1min candle. or I switch down even lower to a 30sec or 10sec chart my system freezes for sometimes up to 30 - 60 seconds on the "loading SCID" text box. Is there anything that may be causing this within the data that I may need to house keep? Kind regards Brad |
[2022-11-21 15:05:21] |
Sierra_Chart Engineering - Posts: 14264 |
This sounds like a study is taking a long time to calculate. Check the calculation times of the studies: Chart Studies: Studies To Graph Most likely you would need to make some changes with Input settings to reduce calculation time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-21 15:06:09
