Date/Time: Wed, 08 May 2024 07:59:03 +0000
Transparency level for the study
View Count: 363
[2022-11-18 16:25:36] |
BillyVLLR - Posts: 14 |
Dear support team, Is there a way to set a transparency level for the study "High/Low for Time Period"? I'm using it to delimitate sessions times (LSE, NYSE, Asia by example) and it would be fantastic to be able to set a transparency level when using the Subgraphs "Draw Style" set to "Fill Top/Bottom". Best regards, Billy |
[2022-11-18 17:52:36] |
John - SC Support - Posts: 31441 |
You need to use the Draw Styles of Transparent Fill Top/Bottom. Then you can apply the Transparency value. Refer to the information here: Chart Studies: Transparent Fill Top (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_TOP) and Transparent Fill Bottom (ACSIL: DRAWSTYLE_TRANSPARENT_FILL_BOTTOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-21 18:17:21] |
Thank you John!
