Date/Time: Mon, 29 Apr 2024 05:56:47 +0000
DOM not working
View Count: 546
[2022-11-13 20:36:45] |
User678193 - Posts: 12 |
I want to start using the DOM for my trading and I pulled it up. When I used Replay to practice watching it, it only showed 1 - 1. How do i get it to work properly? Thanks
Attachment Deleted. Capture.PNG / V - Attached On 2022-11-13 20:35:37 UTC - Size: 18.13 KB - 92 views |
[2022-11-14 13:26:29] |
For futures it brings up more numbers which i like to see. But for an equity it only pulls up one number on the bid and ask. Is there a way to see more information on equities. I'd like to use the DOM for trading equities as well as futures.
Capture.PNG / V - Attached On 2022-11-14 13:26:14 UTC - Size: 71.72 KB - 85 views Attachment Deleted. |
[2022-11-14 15:23:02] |
You are using the U.S. Equities exchange that is part of our Sierra Chart Exchange Data Feed. That exchange does not include the Market Depth data. This is where the tradeoff occurs with our NASDAQ TotalView exchange on our Denali Exchange Data Feed. The NASDAQ TotalView includes the Market Depth, but does not have the consolidated volume from all exchanges for a particular instrument. Therefore, if you need Market Depth over Volume, then we recommend changing to the NASDAQ TotalView exchange, otherwise, you would want to stay on the U.S. Equities exchange that you have now. We are working on getting the consolidated tape for the NASDAQ TotalView exchange and hope to have it by the end of the year. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-14 16:39:06] |
Thank you it fixed the problem. But now i am not seeing data for spy and qqq, what should i do to get them to work properly. It also says that my ES mini futures have delayed data how do i make them real-time?
Attachment Deleted. delayed.PNG / V - Attached On 2022-11-14 16:38:56 UTC - Size: 62.11 KB - 88 views |
[2022-11-14 19:09:10] |
To specify that you are wanting the data from the NASDAQ TotalView instead of our U.S. Equites, you need to add a '-NQTV' to the symbol name. So for SPY, you would need to enter the symbol SPY-NQTV. Your ES is delayed because you are not setup to get any real-time data for the CME Group from us. Refer to the information at the following link for setting up the Denali Exchange Data Feed for the CME Group (be sure you understand the requirements for a non-professional account): Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-14 21:05:21] |
Is this how the numbers on the DOM are suppose to move? I feel it is moving all over the place and the DOMs that i have watched online seem to more straightforward and moving all together.
[2022-11-14 21:16:10] |
I am trying to get my DOM to resemble the one that Jigsaw trading uses. I provided a picture below of what jigsaw DOM looks like
Jigsaw.PNG / V - Attached On 2022-11-14 21:15:54 UTC - Size: 232.1 KB - 100 views Attachment Deleted. |
[2022-11-15 15:49:41] |
You can definitely get it to look like that, apart from the Volume Profile on the right (we do not have a way to put a volume profile within the DOM columns). You have to adjust the column positions as you want them and all the colors can be adjusted. Refer to the following: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-17 10:44:00] |
Sierra_Chart Engineering - Posts: 14126 |
Also refer to: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-29 20:15:47] |
User569276 - Posts: 1 |
hello, I contact you because i need assistant with my DOM : my DOM look like weird and i woold like to try to kix it. i already pay the 25 dollars to have the flux and it's the good one but it's look like this (in the attached picture) and i don't undertand thank you |
Attachment Deleted. Capture.PNG / V - Attached On 2023-10-29 20:14:26 UTC - Size: 31.09 KB - 45 views |
[2023-10-29 20:28:14] |
First of all, the market is closed at this time. Let us wait until the market opens and there is market depth data, and then tell us specifically what you need help with regarding the Trading DOM.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-29 20:28:29
