Date/Time: Fri, 13 Nov 2026 21:36:39 +0000
AMP/CQG BUNDLE
View Count: 3843
[2022-11-06 18:04:08]
User335495 - Posts: 1
Good morning,
my main account is with Interactive and it seems to me that it is not ideal for using Sierra Chart.
For this reason I am evaluating the opening of a second account to be combined with SC.
AMP Futures offers an interesting solution that includes CQG data feed and Sierra package 5, but I'm not sure it's a good choice for performance. Also I have a doubt, can your package 5 be combined with an external data feed?
What I expect to achieve is to mainly analyze SP and Euro Stoxx, with real-time data and the Volume profile and Number Bar tools.
Thanks in advance.
Cristiano
[2022-11-06 18:47:27]
In all cases you will need to use Service Package 10 or 11:
Description of Service Packages and Pricing
And use the Denali Data Feed for market data:
Denali Exchange Data Feed
Did you want to do charting only. Or also do trading?
[2022-11-23 14:10:06]
User827536 - Posts: 1
what is the difference when you say "Did you want to do charting only. Or also do trading?" . I have account with AMPFutures but currently use TradingView for charting and trading. Could i use the same login credentials to connect with Sierra Charts or I will required additional id? it may be broker question but thought you may know.
Additionally, Could I use free historic data and charting before i start using sierra for live trading?
[2022-11-23 16:39:40]
You can use the same CQG credentials. Refer to the following information for how to setup your Sierra Chart to connect to your CQG account:
CQG Trading Platform Service: Setup Instructions
Keep in mind that CQG may have limitations on how many connections there can be at one time.
This tells us whether you need to be continually connected to your CQG account or if you just need to connect to it once a month in order to verify your non-professional standing for the CME Group data. Refer to the following:
Yes, just keep in mind that we have "Free" real-time data for Forex and CFDs, and we have "Free" Delayed Streaming Data for the CME Group, CFE, EUREX, and NASDAQ TotalView. We highly recommend using our Delayed streaming data while you are getting used to Sierra Chart. The data acts, in all ways, like real-time data, but is delayed by 10-15 minutes (depending on exchange). This allows you to work with Sierra Chart without having to pay for the real-time data.
In addition, if you are not going to be connecting to your trading account and you are using the delayed data, then you can be on one of our "Base" packages. Refer to the following:
Description of Service Packages and Pricing: Base Packages
