Date/Time: Fri, 13 Nov 2026 22:08:35 +0000
Creating a macro to go back to
View Count: 941
| [2022-11-03 02:04:07] |
| plethora - Posts: 2 |
I wanted to know if this is possible or not. It's very important to me to use my tools i.e. rays and disable them fast, meaning going back to hand mode in my case (that I set up in a way I can drag the chart to control its view). I see this being done 2 ways: either the moment I click to lay a ray down, it stops being in "ray placement mode" OR placing a ray down and having a macro on my mouse or keyboard to go to "hand" without having to actually click inside my customized control bar on the upper side of the window. Another question I have if it's ok to ask multiple stuff on different topics is: How do I invert my right side scale (I already tried to find something in "scale settings") in order for me to, when click and dragging down, it makes my candles vertically smaller instead of taller (and vice-versa, meaning when I click and drag upwards it makes them taller instead of smaller). Last question, this one is not technical problem at all so feel free to just ignore it: Independently of "when", is there any desire/aspiration/motivation to bring Binance to the list of possible trading service exchanges? Thanks a lot and have a great week! |
| [2022-11-03 15:04:59] |
| John - SC Support - Posts: 48527 |
With regards to changing to the Hand tool after placing a drawing - this is already supported. Refer to the following setting: Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options) With regards to inverting how the scale adjustment works, there is not an option to change this. With regards to Binance - we will not be doing this. The long term goal is to have our own exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-03 15:48:18] |
thank you for the quick response. I've been trading for 3+ years and I'm glad to have something like this service available. I do have to admit that it is a big downside for me to not have the biggest exchange in terms of volume and/or liquidity available but I also understand that there might be reasons that lie on their side of things, meaning problems that they have that you wouldn't want to bring here to your platform to your type of customers. I would for sure trade futures in your own exchange, that's actually massive. Is this something to look forward for the nearby future or is this just a long term vision that ofc will come but in due time (i.e >1 year to go)
| [2022-11-03 17:22:14] |
There are multiple issues with the crypto exchanges and it is simply not something we want to delve into, as we have had enough issues with the Futures exchanges and data and expectations put upon for other vendors issues. As to our own exchange, it is a longer-term item. Definitely more than 1 year out, but it is something we are driving towards. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
