Date/Time: Wed, 08 May 2024 19:30:00 +0000
Problem with Default Right Side Fill Space
View Count: 1114
[2014-05-22 21:13:17] |
User51760 - Posts: 108 |
Hello Support Team, setting Global Settings >> Graphic Settings >> Other >> Default Right Side Fill Space to any number (like 5 or 15 or whatever) would not bring up any effect neither in existing charts nor in new charts: There will not be any default space between chart scale border and current bar. Exiting the platform and restart would not bring up any change in Right Side Fill Space. Tried out SC Version 1132 and 1137. What am I missing? Thank you for your consideration, Chris |
[2014-05-23 01:00:20] |
Al SC Developer - Posts: 434 |
This is working as designed. When the fill space for a chart is not locked, new bars are added into the fill space if there is any, and then the chart is scrolled when further bars are added. When a chart is created, there is fill space, but it is immediately filled as the initial data is loaded. If you hit the "End" key, a chart is scrolled to the end of the chart, and the fill space is set according to this setting. If you always want a certain fill space, then adjust the fill space and lock the fill space for the chart. Date Time Of Last Edit: 2014-05-23 03:28:48
