Date/Time: Mon, 29 Apr 2024 02:30:38 +0000
Rithmic - Denali No historical data
View Count: 330
[2022-11-01 12:14:00] |
User104854 - Posts: 441 |
I am currently trading an evaluation account with Apex. This morning I had to renew the Denali data feed subscription. I am connected to Rithmic but am not getting any historical data over the past 24 hours. Everything worked fine over the past week up until this morning. Does renewing the account have anything to do with it? How do I get the historical data? It seems like it should just happen without changing a lot of settings. Please advise. I've tried the delete and download data but it's not working. When I'm on the Teton data feed I get everything but I'm not getting it when I'm on the Rithmic feed. Everything I read regarding this issue says 'just activate the Denali data feed and everything will work fine'. Please help. Date Time Of Last Edit: 2022-11-01 12:41:43
[2022-11-01 12:37:20] |
Sierra_Chart Engineering - Posts: 14126 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-01 12:43:06] |
Ok I got it fixed. Apparently edit>delete all data and download is different than right clicking on the chart and selecting delete and download data. Using the edit tab and selecting delete all data and download fixed it. Thank you. |
[2022-11-01 13:44:24] |
Yes there is a difference.
