Date/Time: Tue, 29 Sep 2026 13:30:17 +0000
Realtime Data without broker
View Count: 1870
| [2022-10-27 11:30:17] |
| MarcOh - Posts: 176 |
Hi, what package, feed, whatever do I have to book for getting realtime data with denali and sierra chart? Im tired of this rithmic stuff and so want to analyze via tpo in sierra and execute via r trader. But need some help regarding a realtime feed without official broker connection. thx in advance |
| [2022-10-27 15:34:44] |
| John - SC Support - Posts: 48046 |
If you are wanting data from the CME Group, then you will want to have a broker. The CME Group requires that you have a live, funded, futures trading account in order to qualify for the Non-Professional exchange fees. We recommend the service outlined at the following link which will allow you to create an account for as little as $100: Easy Solution to CME Funded Trading Account Requirement In order to verify your trading account, you need to connect your Sierra Chart software to that account at least once a month. If you used the above service, then you would be setup using the Teton Order Routing Service, in which case you would go through the Setup Instructions at the following link to connect to that account (ignore step #5, we'll take care of that next): Sierra Chart Teton Futures Order Routing: Setup Instructions Once that is done, then you would go through the Setup Instructions at the following link for the CME Group data from our Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
