Date/Time: Sun, 05 May 2024 20:34:22 +0000
Setting up Delayed Data - Newbie Question
View Count: 263
[2022-10-20 02:21:35] |
User885565 - Posts: 17 |
Hi, I am completely new to SierraCharts and honestly, it is quite bewildering. I have created an account and I am hoping for a 14 day trial. However I cannot seem to access even the delayed data just so I can see how things work. I notice that on one of the support pages is says.... The Historical Daily data with the Sierra Chart Historical Data Service is fully integrated with all of the supported Trading services as required. There is nothing more that needs to be done to use the Historical Daily data from this service. However when I go to GLOBAL SETTINGS -> Data Trade Services Settings and select SC Data All Services; it says (Not Enabled on Package). If you could help me set up what must be the most basic user settings I would be very grateful. Reg |
[2022-10-20 13:56:19] |
John - SC Support - Posts: 31379 |
Just for others that may come across this thread - in order to activate the trial you need to go through the instructions here: Sierra Chart Trial Account and Account Activation: Details For your account we have activated the trial for you, so you do not need to do the above steps. You will now be able to get the delayed streaming data into the system. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
