Date/Time: Thu, 02 May 2024 16:56:48 +0000
RE CQG DATA
View Count: 266
[2022-10-03 22:17:00] |
User690100 - Posts: 1 |
Hi, I have been with Sierra Charts for many years, but now I need to use the CQG web api for my connection, but in sc settings it is listed as "not enabled on package". my current subscription is package "advanced" no 11.r help!!!! And all the charts dont load. Thanks for you |
[2022-10-03 23:02:08] |
Sierra_Chart Engineering - Posts: 14180 |
There should not be this problem. Follow through the procedure here: Sierra Chart - Software Login Instructions: Forced Login Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
