Date/Time: Fri, 26 Apr 2024 14:52:16 +0000
AMP Rithmic order routing only + Denali Exchange data feed
View Count: 347
[2022-10-03 13:57:05] |
rikki - Posts: 6 |
Hi John, would like to know if this combo is supported. Trade execution and charting on SC with an integrated package (11) and Rithmic just as order routing from AMP. Exchange datafeed is from denali service . If so, what data trade/service setting do I have to choose from the SC menu? (current selected service list) Rithmic direct?! Thanks |
[2022-10-03 14:13:19] |
Sierra_Chart Engineering - Posts: 14101 |
Yes this is supported. Sierra Chart would be set to use Rithmic: Rithmic Trading Platform Service: Setup Instructions Also refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-03 18:16:18] |
rikki - Posts: 6 |
Thanks, MAy I ask you how can I choose the right server among the all?(service settings) |
[2022-10-03 18:37:59] |
For live trading it would be Rithmic 01.
