Date/Time: Fri, 26 Apr 2024 11:19:14 +0000
Second installation
View Count: 284
[2022-10-01 17:08:35] |
User491428 - Posts: 86 |
Hey, now I've installed Sierra a second time, on a second hard drive. I use the same charts and studies but my problems are. The second version of Sierra works slowly. The cathedral works jerkily also the charts... My second question. How it is possible to copy all the settings from the original to the second version. |
[2022-10-02 01:07:18] |
Sierra_Chart Engineering - Posts: 14094 |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often And: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
