Date/Time: Mon, 13 Apr 2026 08:51:16 +0000
incorrect signal
View Count: 679
| [2022-09-30 18:59:06] |
| User411320 - Posts: 373 |
attached is a photo of my chart. the purple candle circled white is being populated and i dont know why. the white line pointing down shows there was no cross from below to generate it. please advise
| [2022-09-30 20:07:53] |
| John - SC Support - Posts: 45586 |
What exactly is the formula being used that generates the purple colored bars?
| [2022-09-30 21:11:30] |
so i use the study "color bar based on alert condition" and the formula is =CROSSFROMBELOW(ID5.SG2,ID5.SG3). Also, it's generating the incorrect signal on all time frames. all other signals on the chart are correct though
| [2022-09-30 21:32:01] |
are ID5.SG2 and ID5.SG3 valid subgraphs and do they actually cross each other? And does ID5.SG2 cross ID5.SG3 from below?
| [2022-09-30 21:42:48] |
yes they're valid and yes they cross each other and yes ID5.SG2 cross ID5.SG3 from below. I can send more pics if that would help
| [2022-09-30 21:49:38] |
This is being handled in the following thread: missing signal Please do not post in additional threads on the same topic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
