Date/Time: Fri, 26 Apr 2024 18:04:42 +0000
buy sell imbalance
View Count: 770
[2022-09-29 15:42:10] |
Ken Smith - Posts: 58 |
Im trying to find the instructions to have my footprint chart show me a market imbalance of 300% or greater. I believe this would be "numbers bars" in Sierra charts. I am referring to the diagonal bid/ask I want to have an imbalance highlighted in bold red/green Thanks Ken |
[2022-09-29 16:39:59] |
John - SC Support - Posts: 31154 |
Refer to the following: Numbers Bars: Display Ask/Bid Imbalance And also the following for another option: Volume at Price Threshold Alert V2: Highlight Multiple Adjacent Bid or Ask Dominant Prices (Stacked Imbalance) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-29 19:27:27] |
Thanks for your help John , but Ive been changing settins for over an hour....Im close but I cant seen to get it where I only see colored boxes when there is an imbalance of 300% Can I send you a screen shot? Thanks again Ken PS. is it possible to have an imbalance show up on another chart?...like an arrow, or small number? Ie: I use 610 ticks for the numbers chart and I also use a 610 candle chart Date Time Of Last Edit: 2022-09-29 19:29:47
[2022-09-29 20:59:49] |
To get the 300% imbalance you would see the Percent Color Thresholds to (0, 0, 3) (the example gives 400% where the values are 0, 0, 4) It is not possible to get the imbalance to show in another chart using the Numbers Bars. But look at the Volume at Price Threshold Alert V2 that we referenced above, as that can be overlaid to another chart and then be referenced for an alert. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
