Date/Time: Sun, 28 Apr 2024 00:32:55 +0000
Real Time data ok but not any history
View Count: 274
[2022-09-29 08:01:46] |
anthod13 - Posts: 1 |
Hello, after a long break I'm starting again using Sierra Chart. I did the rollover of my symbol as i needed it. I'm receiving well the real time data, not any problem with that. My only problem is that i don't have the history between today (29th of september) and the 27th of june. When i go in chart settings, i can't change the Date Range. Thank you. Anthony |
Capture.JPG / V - Attached On 2022-09-29 07:59:45 UTC - Size: 352.34 KB - 64 views |
[2022-09-29 14:33:18] |
You need to make the chart a Continuous Futures Contract Chart. Refer to the information here: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
