Date/Time: Thu, 12 Nov 2026 07:04:21 +0000
Demo account evaluator
View Count: 862
| [2022-09-28 08:22:01] |
| User956873 - Posts: 25 |
Demo account evaluator Followed your instructions from the last message I got as far as stage five tried to connect to data feed but did not work connect to data feed is not highlighted and cannot be activated thanks
| [2022-09-28 14:32:10] |
| John - SC Support - Posts: 48504 |
If the option for File >> Connect to Data Feed is not available to select, then that means that you are already connected to the data feed. Therefore, everything should be working fine for you at this point. Just make sure that you are connecting to the Trading Evaluator - Delayed, since you are using the Delayed Streaming data and not real-time data.
| [2022-09-28 14:51:42] |
Is there a window I can bring up and keep up on my charts so I can see my PNL
| [2022-09-28 17:08:20] |
There are a few options. - You can display the information on your charts using the Trading studies. Refer to the information here: Trading Information Windows: Trading: Profit/Loss Text Study - You can see the information for a chart by viewing the Trade Window for that chart. Refer to the following: Basic Trading and the Trade Window: Main/C >> Open Profit/Loss (P/L) - You can view the information for your accounts using the Trade Activity Log. Refer to the information here: Trade Activity Log For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-29 17:33:38] |
| Sierra_Chart Engineering - Posts: 25415 |
There is also the Trade >> Trade Account Monitor.
| [2022-09-30 08:54:09] |
Sorry I want to turn this demo account valuator off now it’s causing me nothing but trouble I will just make a note of all my trades profit and loss in my journal if you could help thank you
| [2022-09-30 16:52:38] |
To "turn off" the Evaluation account, you just need to change your Global Settings >> Data/Trade Service Settings >> Current Selected Service to something else. If you do not have a trading account that you are connecting to, then set the Current Selected Service to SC Data - All Services. You will then be able to use Sierra Chart in Simulation mode. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
