Date/Time: Fri, 27 Jan 2023 14:21:40 +0000
Cumulative delta reset time issue
View Count: 108
[2022-09-27 17:08:49] |
User423974 - Posts: 12 |
Hi, Iam using the "cumulative delta bars - volume" on sierra version 2363, the issue is if these two options are ticked as No: "reset at start of trading day" and "reset at both sessions start times" I get irrelevant values at right, 616000-628000 , otherswise , with either option selected as yes, I get correct values at right side, but with a cut off of values at 18:00 GMT+3 (my timezone) P.S The chartbook iam using is since 2020 that's why i have an earlier Sw version so it can execute Thanks Date Time Of Last Edit: 2022-09-27 17:09:27
[2022-09-27 17:18:25] |
John - SC Support - Posts: 21711 |
First, if you can open the chart book in 2363, then you can open it in any of the current versions. So that should not stop you from updating. Second, it is hard for us to say what exactly is occurring, but keep in mind that if you are not resetting the Cumulative Delta Bars at the beginning of a session, then you are accumulating the information from the beginning of the chart. So a value of 616000 is certainly possible. It will just depend on how much data you have loaded. If you believe that the numbers are "Correct" when you select the option to reset with the trading day or both sessions, then this is what you would want to do, and you will get the "cutoff" based on your Session Times and how you have the Inputs set. Refer to the following regarding Session Times: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
