Date/Time: Fri, 27 Jan 2023 13:50:52 +0000
please help me with my live trading
View Count: 118
[2022-09-27 16:57:37] |
barryevan77 - Posts: 6 |
Just signed on with CQGand getting a this message now when I try to download my data.Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-27 13:36:35.635 CQG WebSocket socket (0) | CloseSocket call. | 2022-09-27 13:36:35.649 CQG WebAPI | Disconnected. | 2022-09-27 13:36:35.649 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-27 13:36:35.649 CQG WebAPI | Connecting to server api.cqg.com | 2022-09-27 13:36:37.640 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-09-27 13:36:37.640 Error getting address info for api.cqg.com. Windows error code 11001: No such host is known. | 2022-09-27 13:36:37.641 * CQG WebSocket socket (1) | CloseSocket call. | 2022-09-27 13:36:37.641 CQG WebSocket | WebSocket closed. | 2022-09-27 13:36:37.641 CQG WebAPI | WebSocket closed. | 2022-09-27 13:36:37.641 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-09-27 13:36:37.641 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-27 13:36:37.641 CQG WebSocket socket (0) | CloseSocket call. | 2022-09-27 13:36:37.656 CQG WebAPI | Disconnected. | 2022-09-27 13:36:37.656 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-09-27 13:36:37.656 CQG WebAPI | Connecting to server api.cqg.com | 2022-09-27 13:36:39.669 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-09-27 13:36:39.669 |
[2022-09-27 17:08:48] |
John - SC Support - Posts: 21711 |
The only way you should be getting the following message is if you are not connected to the Internet, or if you are connecting through a corporate connection that only allows for certain connections: Error getting address info for api.cqg.com. Windows error code 11001: No such host is known. | 2022-09-27 13:36:37.641 *
api.cqg.com is a well-established domain name, so you should not have any issues connecting to it, apart from what we stated above. If you know how to open a Command Prompt, then do so and enter ping api.cqg.com and see if you get a response or not. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-28 08:19:00] |
Sierra_Chart Engineering - Posts: 6328 |
Try flushing the DNS cache: The Domain Name Service on your computer or with your ISP is not functioning properly. The error message in the Window >> Message Log would contain the text: No such host is known or you may get a message similar to the following: Windows error code 11002: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
In this case you may want to try restarting your computer or going to the command line and entering the following: ipconfig /flushdns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
