Date/Time: Fri, 27 Jan 2023 13:56:51 +0000
SierraChart/CQG lack of datafeed speed in the DOMs
View Count: 128
[2022-09-25 08:39:22] |
A.J. - Posts: 20 |
SierraChart/CQG + Broker: AMP Futures Dear SierraChart-Team, there is a performance problem with the datafeed in the DOMs with CQG. The speed from the datafeed in my just 3 open DOMs is much too slow and is thus not mapped correctly. All the charts are showing the correct price trend in each case at each time, but not the 3 DOMs. It looks like not all ticks that are traded are mapped. question 1: what is the reason from this issue (filtered ticks? something else): question 2: how can this be fixed: Remark: I want to restart trading after several years time out. I wondered, why the price changes in the DOMs have suddenly become so slow. It is not my up-to-date trading PC, because I have checked other trading platforms with CQG-datafeed and all of them were much faster. I hope you have a solution for this issue, because I love your software and want to stay with it and your great service. (In former days I used SierraChart/CQG on my 9 screens 9 DOMs, plenty of charts at the same time and always the speed of data supply was excellent. What has changed? I would like to know that.) Thank you very much for your time and support! Best greetings from Germany, Alexander |
[2022-09-25 09:04:37] |
User150671 - Posts: 27 |
Multiple threads in here already about increasing DOM performance. Step 1 would be checking the Chart Update Interval under Chart > Chart Settings > Display > Chart Update Interval in Milliseconds 0 is global which is 500ms by default I think - way too slow for a DOM but fine for general charting I guess. I use 20ms for my Primary and Fast Markets (think NQ or CL), everything else sits on 50ms. There has been a lot of research into perception speed - some studies suggest as little as 13ms is possible for the human brain to interpret an image, others suggest 50-60ms in normal light conditions is best case. There is an argument for having DOMs in a separate Instance as well, in my personal use I have found this unnecessary, but depending on your use case you may find beneficial. |
[2022-09-25 10:24:38] |
Sierra_Chart Engineering - Posts: 6328 |
Refer to: Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM The first thing to do is just open a single Trading DOM without any studies in an instance and lower the Chart Update Interval to about 50 ms, and then evaluate the performance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-25 13:24:25] |
A.J. - Posts: 20 |
Dear SierraChart-Team and dear User150671, thank you very(!) much for your quick and very interesting replies! I will check it out tomorrow on monday. I wish you a great Sunday and remain with my best regards, Alexander |
[2022-09-26 17:01:51] |
A.J. - Posts: 20 |
Dear SierraChart-Team and dear User150671, it worked!! The datafeed quality is great and as it should be!! Thank you very very much!! I wish you guys all the best and great profits!! :-) With the best greetings from germany, Alexander |
