Date/Time: Mon, 29 Apr 2024 14:41:45 +0000
Request CBOE $VXST symbol be added to Indexes/Stats
View Count: 1199
[2014-05-16 08:48:39] |
inthetrend - Posts: 33 Invalid SC Account Name. |
CBOE describes this as a Short Term VIX index. It is a relatively new index for the CBOE, with both Futures and Options trading against it. I use it via my MB Trading account for options trading. However, I have found it helpful in trading the CME's ES contract on shorter time frames. It is based on options that go out a maximum of 7-9 days. Therefore, it is perfect for trading intra-day, and not only for options. I definitely find value in it and encourage you to add this symbol to Sierra Chart data offerings. I am sure you would get lots of interest from traders. |
[2014-05-16 16:14:32] |
You will find this exact symbol listed in File >> Find Symbol. If you do not see it, then update Sierra Chart to the latest version with Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
