Date/Time: Mon, 29 Apr 2024 15:27:43 +0000
DELAYED DATA WITH DENALI ?
View Count: 399
[2022-07-08 01:39:06] |
User709073 - Posts: 5 |
Hello Gentlemen, My Denali feed is being delayed by about 10 minutes? I made two separate payments. One for $36 and another one for $10, for a total of $46. I have two other software platforms that are using IQ Feed and both are real-time. When I change Sierra back to IQ Feed, that data is also real-time. But when I select SC Data - All Services the data is delayed by 10 minute. What needs to be done on my end? Anything on your end? Thank you. |
[2022-07-08 05:46:05] |
You need to go through the Denali Exchange Data Feed set up instructions here: Denali Exchange Data Feed You did not complete any market data agreements and you have no exchanges active. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-08 05:46:13
