Date/Time: Thu, 11 Dec 2025 06:52:47 +0000
Bid and Ask Market Orders Column in DOM
View Count: 1576
| [2022-06-24 17:31:58] |
| countryboy92 - Posts: 101 |
In my DOM I have added each of 2 columns, Bid Market Orders Column and Ask Market Orders Column. I have also gone into Global Settings > Symbol Setting > and for .F.JS.EP?## I have set the Minimum Market by Order Quantity to "50", but when the market is open even during the busiest time, I am getting only blanks in this column, instead of single market orders of 50 or greater.
| [2022-06-24 17:59:02] |
| John - SC Support - Posts: 43413 |
First of all, you are not on Package 12. You need to be on Package 12 in order to get the MBO data. We have gone ahead and set your account to evaluate package 12 for 60 days. If you are going to continue to use the MBO data after these 60 days, then be sure you change your Package to package 12 before the time is up. Also, review the Setup Instructions at the following link, as there are a few other things to take care of: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-08-17 20:47:30] |
| User930894 - Posts: 1 |
Hi There, Im in a similiar boat, can I get package 12 for 60 days to evaluate? |
| [2023-08-17 21:31:41] |
User930894: We have set your account to evaluate Package 12 for 30 days. At the time of the writing of the initial request by the other user, the evaluation of Package 12 was 60 days. It has changed to only 30 days now. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
