Date/Time: Sat, 12 Jul 2025 00:55:58 +0000
Dom price displayed
View Count: 4848
[2013-03-22 16:23:50] |
tr726 - Posts: 30 |
is there a way to display the last three price digets on the dom ladder? example: 10 year treasury price is 131'150, dom would show 150.
[2013-03-22 17:12:26] |
Yes of course. Please post an image of what you see now, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-23 19:20:24] |
tr726 - Posts: 30 |
http://www.sierrachart.com/image.php?l=1364066390250.png |
[2013-03-23 19:25:41] |
tr726 - Posts: 30 |
I'm referring to the price column here; so say the last traded price of 131'15.00 can i displace a price use just 150?
[2013-05-14 22:23:08] |
WarEagle - Posts: 73 |
Was there any resolution to this? I am interested as well. If there is nothing already available maybe add a setting in the chart properties to eliminate a set number of significant digits. For example 0 would be all digits (ES = 1647.00), 1 would remove the first (ES = 647.00), 2 the first and second (ES = 47.00) etc, etc. It would make the DOM easier to read and save screen space. Date Time Of Last Edit: 2013-05-14 22:23:26
[2020-04-17 17:27:44] |
User135370 - Posts: 162 |
Is there a response to this from Sierra I would also like to show the last 2 digits on the bonds in time and sales mainly
[2020-04-17 21:37:17] |
seandunaway - Posts: 352 |
+1; I know it's an odd request but many of us are used to it from TT/Jigsaw.
[2020-04-17 22:17:38] |
Where were you guys 7 years ago when I needed the extra voices? LOL j/k I never found a solution for this but haven't tried since I stopped scalping bonds years ago. I recreated most of the TT UI in Sierra (I even built my own EPIQ), but just not the DOM price display part. |
[2020-04-19 02:08:37] |
We are going to be adding a simple setting to display a specified number of rightmost digits for prices in the Time and Sales window and also the price scale on the chart.
[2020-04-19 21:03:57] |
User495158 - Posts: 108 |
Right now it is possible to acomplish this by setting up price scale on the far left of the DOM window and "cutting" the window size so that it displays just the decimal part or whatever you may need. See the screen. Date Time Of Last Edit: 2020-04-19 21:09:39
[2020-04-20 03:59:38] |
How do you cancel and adjust resting orders?
[2020-04-20 07:17:21] |
I don't need to do that. I use this display with DOM window size reduced only for my correlated markets, not the one I trade. The one I trade I don't reduce the window size so I can manipulate orders. But the benefits are significant since I have a lot of DOM windows open. Date Time Of Last Edit: 2020-04-20 07:19:07
[2020-05-01 09:40:40] |
Reference to Sierra's comment #9 above which read: We are going to be adding a simple setting to display a specified number of rightmost digits for prices in the Time and Sales window and also the price scale on the chart. Was this added in the new version? Date Time Of Last Edit: 2020-05-01 09:40:52
[2020-05-04 10:18:59] |
The setting exists but it is not yet implemented. We will get to this as soon as possible.
[2020-06-09 16:47:17] |
j4ytr4der_ - Posts: 947 |
I just discovered this thread, have been wondering the same thing. +1 here for seeing this added ASAP. Also fixing the issue with being unable to cancel resting orders in the DOM if the values scale is hidden (I made my own thread about that today before I found this one).
[2020-10-14 17:04:59] |
John - SC Support - Posts: 40857 |
The setting for Chart Settings >> Advanced Settings 3 >> Limit Price Displayed To N Right Characters is now implemented and functional. You will find the documentation for this here: Chart Settings: Limit Price Displayed to N Right Characters (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-19 03:01:23] |
Just a quick note on this, the feature works and that's great. Unfortunately the main reason for it for me, was to save a bit of horizontal screen space by reducing the number of digits of price. In this case, the width of the price column does not shrink to the corresponding size of the reduced digits. If that's something you could change, it would be greatly appreciated. As it stands currently this feature serves no purpose for me at least. =(
[2020-10-29 17:24:02] |
BreadWinner'sAssoc. - Posts: 7 |
Is there a chance that being able to adjust the width of the values column be implemented at some point? This would be extremely beneficial to me and probably many others as well. I appreciate all the hard work and am not trying to push this feature. I just want to know if there is any possibility that this can be done given the structure of program. Thanks, SC Support! Edit: I have tried Chart >> Reload and Recalculate, however the change in width is negligible. Date Time Of Last Edit: 2020-10-29 17:29:31
[2021-12-29 17:57:44] |
riskanalysisteam - Posts: 1 |
+ 1 for this.
