Date/Time: Sun, 01 Nov 2026 08:24:04 +0000
Failure to connect/dowload data for FGBLU22-EUREX from IB
View Count: 601
[2022-06-21 08:26:42]
philkalabine - Posts: 1
Reading Internal Order ID file. | 2022-06-21 10:24:06.187
Reading Trade Orders file. | 2022-06-21 10:24:06.233
Reading Trade Positions file. | 2022-06-21 10:24:06.233
Reading Trade Account Data files. | 2022-06-21 10:24:06.234
UDPListener (1592). Port 22904 | Listening on UDP port 22904. | 2022-06-21 10:24:06.244
Software version: 2394 64-bit | 2022-06-21 10:24:06.244
Primary Thread ID: 12508 | 2022-06-21 10:24:06.244
Usage end date: 2022-09-07 | 2022-06-21 10:24:06.244
Enabled for: Advanced Features 2. | 2022-06-21 10:24:06.244
Enabled for: Sierra Chart Historical Data Service. | 2022-06-21 10:24:06.244
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-06-21 10:24:06.244
Enabled for: Delayed Denali Exchange Data Feed. | 2022-06-21 10:24:06.244
Enabled for exchange2: fairx_exchange.data | 2022-06-21 10:24:06.244
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-06-21 10:24:06.244
Current selected Data/Trading service: Interactive Brokers | 2022-06-21 10:24:06.244
Custom symbol settings values: enabled | 2022-06-21 10:24:06.244
Chart Update Interval: 500 | 2022-06-21 10:24:06.244
Intraday Data Storage Time Unit: 1 | 2022-06-21 10:24:06.244
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2022-06-21 10:24:06.244
2022-06-21 08:24:06 Local computer time in UTC | 2022-06-21 10:24:06.244
2022-06-21 10:24:06 Local computer time in SC Time Zone | 2022-06-21 10:24:06.244
2022-06-21 08:24:04 Server time in UTC | 2022-06-21 10:24:06.244
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-06-21 10:24:06.244
Program path: D:\GTC CLE USB\SierraChartPhilippe\ | 2022-06-21 10:24:06.244
Data Files path: D:\GTC CLE USB\SierraChartPhilippe\Data\ | 2022-06-21 10:24:06.244
OS Version Number: 10.0 | 2022-06-21 10:24:06.244
Locale Setting: C | 2022-06-21 10:24:06.244
DLLs: UserContributedStudies_64.dll | 2022-06-21 10:24:06.244
Allowed protected custom studies: | 2022-06-21 10:24:06.244
Crash reporter started: true | 2022-06-21 10:24:06.244
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2022-06-21 10:24:06.254
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-06-21 10:24:06.279
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-06-21 10:24:06.343
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-06-21 10:24:06.343
Received 5 login tokens. | 2022-06-21 10:24:06.475
Symbol settings MD5 received. Request ID: 1. | 2022-06-21 10:24:07.962
Symbol settings are up-to-date for interactive_brokers.trading. | 2022-06-21 10:24:07.962
Files to Open on Startup | Opening file: BUND.cht | 2022-06-21 10:24:10.627
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.644
FGBLZ21-EUREX 1 Min #4 | Reloading chart. | 2022-06-21 10:24:10.644
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.645
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.646
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.707
FGBLZ21-EUREX #1 | Reloading chart. | 2022-06-21 10:24:10.707
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.708
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.710
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.712
FGBLZ21-EUREX 1 Min #2 | Reloading chart. | 2022-06-21 10:24:10.712
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.713
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.714
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.717
FGBLZ21-EUREX 5 Min #5 | Reloading chart. | 2022-06-21 10:24:10.718
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.719
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.720
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.722
FGBLZ21-EUREX #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-06-21 10:24:10.722
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.733
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.790
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:10.825
Using symbol data fast lookup vector | 2022-06-21 10:24:11.154
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2022-06-21 10:24:12.714
IB TWS socket (1) | Creating socket. | 2022-06-21 10:24:12.715
IB TWS socket (1) | New receive buffer size: 5242880 | 2022-06-21 10:24:12.715
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2022-06-21 10:24:12.715
Interactive Brokers | Sending API sign: API | 2022-06-21 10:24:13.223
Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2022-06-21 10:24:13.223
Interactive Brokers | TWS server version: 136 | 2022-06-21 10:24:13.232
Interactive Brokers | TWS time: 20220621 10:24:11 CET | 2022-06-21 10:24:13.232
Interactive Brokers | Connected. Sending Start API command. | 2022-06-21 10:24:13.484
Interactive Brokers | Waiting for account information. | 2022-06-21 10:24:13.484
Next valid order ID: 1 | 2022-06-21 10:24:13.490
Message from IB: La connexion de donn�es de march� est OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.491
IB Account information received. | 2022-06-21 10:24:13.491
Interactive Brokers | Received 1 Trade Accounts from TWS. | 2022-06-21 10:24:13.491
Interactive Brokers | Connected to Live account. | 2022-06-21 10:24:13.491
Updated verified funded futures trading account ending date to: 2022-07-21 08:24:13 | 2022-06-21 10:24:13.491
Interactive Brokers | Connected to server complete. | 2022-06-21 10:24:13.491
Triggering next historical data download in queue. | 2022-06-21 10:24:13.491
Updated verified funded futures trading account ending date to: 2022-07-21 08:24:13 | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es de march� est OK:eufarmnj. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es de march� est OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es de march� est OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es de march� est OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es de march� est OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es de march� est OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es de march� est OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es HMDS est OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es HMDS est OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de donn�es HMDS est OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2022-06-21 10:24:13.498
Message from IB: La connexion de la batterie de serveurs Sec-def est OK:secdefeu. IB Error Code: 2158. Request ID: -1. | 2022-06-21 10:24:13.498
No download requests in the queue to start downloads for. | 2022-06-21 10:24:13.498
Next valid order ID: 1 | 2022-06-21 10:24:13.499
Using symbol data fast lookup vector | 2022-06-21 10:24:13.670
Interactive Brokers | Starting real-time market data updates for: FGBLZ21-EUREX. ID: 1 | 2022-06-21 10:24:13.670
Interactive Brokers | Subscribing to Symbol: FGBLZ21, SecurityType: EUREX, Expiration: , Exchange: , Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-06-21 10:24:13.671
Interactive Brokers | Requesting security definition data for: FGBLZ21-EUREX. ID: 1 | 2022-06-21 10:24:13.671
Interactive Brokers | Using primary service for historical data for FGBLZ21-EUREX | 2022-06-21 10:24:13.671
Starting DelayedDownloadMonitoringTimer | 2022-06-21 10:24:13.671
Starting HDTimeoutTimer | 2022-06-21 10:24:13.671
Added historical Intraday data request for FGBLZ21-EUREX to the queue. | 2022-06-21 10:24:13.671
Intraday data recording state for symbol FGBLZ21-EUREX is set to download 'Pending'. | 2022-06-21 10:24:13.671
Triggering next historical data download in queue. | 2022-06-21 10:24:13.671
Delaying start of download for FGBLZ21-EUREX. | 2022-06-21 10:24:13.671
Message from IB: Erreur de validation de la demande.-'bW' : cause - Please enter exchange. IB Error Code: 321. Request ID: 1. Symbol: FGBLZ21-EUREX | 2022-06-21 10:24:13.771
Message from IB: Erreur de validation de la demande.-'bQ' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 1. Symbol: FGBLZ21-EUREX | 2022-06-21 10:24:14.672
Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U107* | 2022-06-21 10:24:16.493
Interactive Brokers | Received Trade Positions download end message for account U107* | 2022-06-21 10:24:16.499
Interactive Brokers | Begin Trade Positions processing. | 2022-06-21 10:24:16.499
Interactive Brokers | Received Trade Positions for all accounts. Performing final processing. | 2022-06-21 10:24:16.499
Requesting market depth updates for: FGBLZ21-EUREX if supported. | 2022-06-21 10:24:18.491
Message from IB: Erreur de validation de la demande.-'bX' : cause - Please enter exchange. IB Error Code: 321. Request ID: 100001. | 2022-06-21 10:24:18.495
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.782
FGBLU22-EUREX 1 Min #5 | Reloading chart. | 2022-06-21 10:24:18.783
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.784
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.786
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.815
FGBLU22-EUREX #6 | Reloading chart. | 2022-06-21 10:24:18.815
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.817
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.819
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.839
FGBLU22-EUREX #3 | Reloading chart. | 2022-06-21 10:24:18.839
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.840
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.841
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.940
FGBLU22-EUREX #1 | Reloading chart. | 2022-06-21 10:24:18.941
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.941
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.943
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.974
FGBLU22-EUREX 240 Min #2 | Reloading chart. | 2022-06-21 10:24:18.974
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.975
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.976
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.993
FGBLU22-EUREX 1 Min #4 | Reloading chart. | 2022-06-21 10:24:18.994
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.995
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:18.996
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.004
FGBLU22-EUREX 30 Min #7 | Reloading chart. | 2022-06-21 10:24:19.005
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.006
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.007
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.018
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.035
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.063
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.118
FGBLU22-EUREX #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-06-21 10:24:19.118
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.122
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.129
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:19.143
Interactive Brokers | Starting real-time market data updates for: FGBLU22-EUREX. ID: 2 | 2022-06-21 10:24:19.273
Interactive Brokers | Subscribing to Symbol: FGBLU22, SecurityType: EUREX, Expiration: , Exchange: , Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2022-06-21 10:24:19.273
Interactive Brokers | Requesting security definition data for: FGBLU22-EUREX. ID: 2 | 2022-06-21 10:24:19.273
Interactive Brokers | Using primary service for historical data for FGBLU22-EUREX | 2022-06-21 10:24:19.273
Added historical Intraday data request for FGBLU22-EUREX to the queue. | 2022-06-21 10:24:19.273
Intraday data recording state for symbol FGBLU22-EUREX is set to download 'Pending'. | 2022-06-21 10:24:19.273
Triggering next historical data download in queue. | 2022-06-21 10:24:19.273
Message from IB: Erreur de validation de la demande.-'bW' : cause - Please enter exchange. IB Error Code: 321. Request ID: 2. Symbol: FGBLU22-EUREX | 2022-06-21 10:24:19.279
Message from IB: Erreur de validation de la demande.-'bQ' : cause - Please enter a valid security type. IB Error Code: 321. Request ID: 2. Symbol: FGBLU22-EUREX | 2022-06-21 10:24:19.394
FGBLU22-EUREX #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-06-21 10:24:19.430
Requesting market depth updates for: FGBLU22-EUREX if supported. | 2022-06-21 10:24:23.502
Message from IB: Erreur de validation de la demande.-'bX' : cause - Please enter exchange. IB Error Code: 321. Request ID: 100002. | 2022-06-21 10:24:23.504
Unsubscribed from market depth data for FGBLZ21-EUREX | 2022-06-21 10:24:28.503
Message from IB: Can't find the subscribed market depth with tickerId:100001. IB Error Code: 310. Request ID: 100001. | 2022-06-21 10:24:28.505
HD Request # 1 | Downloading Intraday chart data for FGBLZ21-EUREX to the file FGBLZ21-EUREX.scid. Service: interactive_brokers.trading | 2022-06-21 10:24:29.752
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:29.753
HD Request # 1 | Download start date-time: 2021-12-17 09:24:29.000000. File last date-time: 2021-12-08 12:29:40.537000 | 2022-06-21 10:24:29.753
HD Request # 1 | Requesting a total of 21 days and 0 seconds. | 2022-06-21 10:24:29.753
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2022-06-21 10:24:29.753
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-01 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.753
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200002. | 2022-06-21 10:24:29.756
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1641600. | 2022-06-21 10:24:29.756
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-02 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.756
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200003. | 2022-06-21 10:24:29.759
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1555200. | 2022-06-21 10:24:29.759
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-03 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.759
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200004. | 2022-06-21 10:24:29.762
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1468800. | 2022-06-21 10:24:29.762
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-04 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.762
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200005. | 2022-06-21 10:24:29.765
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1382400. | 2022-06-21 10:24:29.765
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-05 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.765
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200006. | 2022-06-21 10:24:29.768
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1296000. | 2022-06-21 10:24:29.768
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-06 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.768
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200007. | 2022-06-21 10:24:29.771
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1209600. | 2022-06-21 10:24:29.771
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-07 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.771
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200008. | 2022-06-21 10:24:29.774
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1123200. | 2022-06-21 10:24:29.774
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-08 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.774
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200009. | 2022-06-21 10:24:29.775
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1036800. | 2022-06-21 10:24:29.775
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-09 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.775
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200010. | 2022-06-21 10:24:29.775
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 950400. | 2022-06-21 10:24:29.775
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-10 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.775
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200011. | 2022-06-21 10:24:29.777
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 864000. | 2022-06-21 10:24:29.777
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-11 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.777
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200012. | 2022-06-21 10:24:29.778
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 777600. | 2022-06-21 10:24:29.778
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-12 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.778 *
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200013. | 2022-06-21 10:24:29.779
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 691200. | 2022-06-21 10:24:29.779
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-13 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.779
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200014. | 2022-06-21 10:24:29.780
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 604800. | 2022-06-21 10:24:29.780
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-14 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.780
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200015. | 2022-06-21 10:24:29.781
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 518400. | 2022-06-21 10:24:29.781
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-15 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.781
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200016. | 2022-06-21 10:24:29.781
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 432000. | 2022-06-21 10:24:29.781
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-16 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.781
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200017. | 2022-06-21 10:24:29.782
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 345600. | 2022-06-21 10:24:29.782
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-17 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.782
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200018. | 2022-06-21 10:24:29.785
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 259200. | 2022-06-21 10:24:29.785
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-18 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.785
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200019. | 2022-06-21 10:24:29.796
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 172800. | 2022-06-21 10:24:29.796
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-19 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.796
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200020. | 2022-06-21 10:24:29.797
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 86400. | 2022-06-21 10:24:29.797
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-20 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.797
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200021. | 2022-06-21 10:24:29.797
HD Request # 1 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 0. | 2022-06-21 10:24:29.797
HD Request # 1 | Requesting 1 Day of data at 30 secs with ending date-time at 2022-06-21 11:34:29 for FGBLZ21-EUREX. PriceType:TRADES | 2022-06-21 10:24:29.797
HD Request # 1 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200022. | 2022-06-21 10:24:29.798
HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for FGBLZ21-EUREX | 2022-06-21 10:24:29.798
HD Request # 1 | Completion time: 0s. | 2022-06-21 10:24:29.798
HD Request # 1 | Intraday data download complete for FGBLZ21-EUREX. Unique request ID: 1 | 2022-06-21 10:24:29.798
Removing historical data download ID 1. | 2022-06-21 10:24:29.798
Real-time Intraday chart data file updates started for FGBLZ21-EUREX | 2022-06-21 10:24:29.798
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:29.798
Opened cached Intraday file: D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLZ21-EUREX.scid. Thread ID: 12508 | 2022-06-21 10:24:29.798
Intraday chart data file opened for FGBLZ21-EUREX | 2022-06-21 10:24:29.798
HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-06-21 10:24:29.798
Triggering next historical data download in queue. | 2022-06-21 10:24:29.798
Delaying start of download for FGBLU22-EUREX. | 2022-06-21 10:24:29.798
HD Request # 2 | Downloading Intraday chart data for FGBLU22-EUREX to the file FGBLU22-EUREX.scid. Service: interactive_brokers.trading | 2022-06-21 10:24:35.789
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:35.790
HD Request # 2 | Download start date-time: 2022-06-20 18:03:27.000000. File last date-time: 2022-06-20 18:03:27.000000 | 2022-06-21 10:24:35.790
HD Request # 2 | Requesting a total of 0 days and 63668 seconds. | 2022-06-21 10:24:35.790
HD Request # 2 | IB Backfill - Seconds requested: 63668. Seconds Remaining: 0. | 2022-06-21 10:24:35.790
HD Request # 2 | Requesting 63668 Seconds of data at 30 secs with ending date-time at 2022-06-21 11:34:35 for FGBLU22-EUREX. PriceType: TRADES | 2022-06-21 10:24:35.790
HD Request # 2 | Message from IB: Erreur de validation de la demande.-'bS' : cause - Please enter exchange. IB Error Code: 321. Request ID: 200023. | 2022-06-21 10:24:35.794
HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for FGBLU22-EUREX | 2022-06-21 10:24:35.794
HD Request # 2 | Completion time: 0s. | 2022-06-21 10:24:35.794
HD Request # 2 | Intraday data download complete for FGBLU22-EUREX. Unique request ID: 2 | 2022-06-21 10:24:35.794
Removing historical data download ID 2. | 2022-06-21 10:24:35.794
Real-time Intraday chart data file updates started for FGBLU22-EUREX | 2022-06-21 10:24:35.794
File compression not supported on file system. D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Windows error code 1: Fonction incorrecte. | 2022-06-21 10:24:35.794
Opened cached Intraday file: D:\GTC CLE USB\SierraChartPhilippe\Data\FGBLU22-EUREX.scid. Thread ID: 12508 | 2022-06-21 10:24:35.794
Intraday chart data file opened for FGBLU22-EUREX | 2022-06-21 10:24:35.794
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2022-06-21 10:24:35.794
Triggering next historical data download in queue. | 2022-06-21 10:24:35.794
No download requests in the queue to start downloads for. | 2022-06-21 10:24:35.794
[2022-06-21 10:23:59]
Regarding this:
Update to the current version of Sierra Chart:
And set the following option to No:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#SupportIntradayFileCompression
Regarding FGBL, you are not using the correct symbol. Use this Edit menu command to translate the symbols to the correct symbols:
Edit Menu: Edit >> Translate Symbols To Current Service
