Date/Time: Fri, 03 May 2024 12:54:17 +0000
data
View Count: 362
[2022-06-14 19:09:37] |
User391439 - Posts: 5 |
when i scroll out my chart all the bars merge and gives no clarity, same with my delta at bottom. how do i fix this?
[2022-06-14 19:29:43] |
John - SC Support - Posts: 31334 |
We are not sure what exactly the core issue is. Is the issue that you want the scroll wheel to act differently, then refer to the following setting: General Settings Window: Scroll Wheel Setting (Global Settings >> General Settings >> GUI >> Scroll) If you are unsure about how to change bar spacing in/out, then refer to the following: Changing Chart Bars Period If it is something else, then please give us more information on the exact nature of the problem so we can help you solve it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-14 19:31:50] |
https://www.sierrachart.com/image.php?Image=1655235022375.png
[2022-06-14 19:38:20] |
The image does not give us any additional information. If you want to have fewer bars with more separation, then that is what the Bar Spacing is about. Refer to the information we gave above regarding bar spacing. If it is still something else, then please tell us with more detail, as to core issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-14 19:38:59] |
on my other tradovate chart it looks less bunched when pulled out same settings, even the delta can barely see the bars. i trade with apteros and there delta looks far more defined.
[2022-06-14 19:49:41] |
We can't say anything in regards to how other systems look in comparison. That is a personal issue and is not something we can resolve. But, if there is a specific issue in terms of something not being correct, then let us know and we will figure out what the issue is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
