Date/Time: Sat, 05 Jul 2025 18:30:12 +0000
list of brokers
View Count: 20815
[2022-06-14 18:13:01]
User748664 - Posts: 14
Where can I find a list of brokers sieera charts support? I can't seem to find it.
Thanks.
[2022-06-14 18:49:05]
John - SC Support - Posts: 40745
In general, we work with any broker that utilizes CQG, Rithmic, or the Teton Order Routing Service for their order routing. We also have support for Interactive Brokers.
A list of brokers is at the following link:
https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php#Brokers
In terms of our own Teton Order Routing Service, the specific brokers for this are listed at Step #2 at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2022-06-14 18:59:47]
Thanks.
[2024-03-29 05:51:22]
User333086 - Posts: 1
I have a question. Can you link ICmarkets with sierra charts? I’ve heard that it is possible. Thank you for your answer
[2024-03-29 14:06:15]
ICMarkets trades FOREX and CFDs. As such, they do not use one of the futures order routing services that we can connect to (Teton, CQG, and Rithmic). Therefore, we do not have connectivity with them.
It is possible that a third party has created a tool to connect with them, which is the only way that we can think that you may have heard that there is connectivity. This is something outside of Sierra Chart, so it is not something we can help with.
[2024-11-08 06:39:28]
User509533 - Posts: 76
Good evening,
I’m interested in setting up auto trading for TLT using Sierra Chart, as ZN is too large and 10Y lacks sufficient volume. Could you recommend a suitable broker?
Thank you!
[2024-11-08 14:49:25]
By "TLT" are you referring to the "iShares 20+ Year Treasury Bond ETF" traded on the NASDAQ?
If so, then the only broker we work with that supports equity trading is Interactive Brokers.
[2024-11-08 16:22:36]
Thank you, John.
I read on the support board that equity trading using Sierra Chart with Interactive Brokers had some challenges in the past. Is this still the case? What potential issues should I be aware of with automated trading on Interactive Brokers?
[2024-11-08 18:15:12]
There can be issues with Interactive Brokers. Refer to the information at the following link:
Interactive Brokers Trading Service
