Date/Time: Sat, 04 May 2024 06:43:54 +0000
[User Discussion] - Failing to Create Custom Symbol 100*{NVOL-SP}/{TVOL-SP}
View Count: 339
[2022-06-14 09:39:16] |
Techotomy - Posts: 104 |
I don't see any chart data generated for the custom symbol 100*{NVOL-SP}/{TVOL-SP} after following the instructions in Custom Calculated Symbols for constructing a Custom Symbol. The option for Use Custom Symbol Settings Values is Enabled. I added 100*{NVOL-SP}/{TVOL-SP} to the New Symbol box. I set Uses Formula Operators setting to Yes and Download Historical Data for Formula Symbol to yes.
[2022-06-14 10:16:07] |
The data finally appeared when following Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying Downloading of Intraday Data to reconnect. Not sure why the software is not intelligent enough to figure this out on it's own. However, the output has impossible values. The absolute value of NVOL cannot be greater than TVOL, yet i'm getting impossible values below -100 for 100*{NVOL-SP}/{TVOL-SP} at the open for the SPY (e.g. 6/13/2022).
