Date/Time: Fri, 03 May 2024 00:37:20 +0000
Stochastic Oscillator
View Count: 397
[2022-06-13 15:43:29] |
Lilylaw - Posts: 10 |
Dear Sierra Chart, When i search for studies of "Stochastic Oscillator", there's no exact name search found under the available studies. When i try the "Stochastic Momentum Indicator", the indicator has 100 to -100 range, but for traditional Stochastic Oscillator, the range should be 0 - 100. May i know which study name is for the traditional "Stochastic Oscillator" indicator? Thanks. |
[2022-06-13 16:39:49] |
If you simply want to calculate the difference between two different stochastic lines then use the Study Subgraphs Difference study documented here: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
