Date/Time: Wed, 08 May 2024 02:23:49 +0000
PNL Display
View Count: 951
[2022-06-13 13:29:37] |
mreis - Posts: 2 |
hi I am on sim using micro. the PNL shown is what exactly? Is it -33 dollars and 75 cents? I need to know these things before I go live. Attachment is included here. |
[2022-06-13 16:06:04] |
John - SC Support - Posts: 31441 |
The Net P/L that is shown is -$33.75. You have the profit/loss set to show as Currency, and since that particular product is traded in dollars, the currency is then in dollars. Just be sure that you have the correct setting for the Currency Value per Tick, as you are using a Trade and Current Quote Symbol, so your Currency Value Per Tick needs to be set for the trading symbol. Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-14 11:24:10] |
mreis - Posts: 2 |
I see. I had a look at the link you have sent and the same time I understand, I am a bit lost as I'm new to this platform and it's a lot of info to take in. Attached, I have got a screenshot of my symbol settings. Are they correct for S&P500? Most importantly, am I actually in micro? If yes, how to I change it to full size? For what I can understand, changing "use as trade only symbol" to NO would suffice. Is this correct? Until I hear from you, I will continue to trying to understand the link you've sent. Please advise. |
Symbol.png / V - Attached On 2022-06-14 10:54:00 UTC - Size: 151.84 KB - 103 views |
[2022-06-14 12:52:21] |
The Currency Value per Tick setting is correct for the chart based upon the Trade Symbol you are using. Also refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-14 12:53:45
[2022-06-14 15:25:03] |
If you just want to trade the e-Mini S&P 500 and not the Micro, then you would need to remove the symbol from the Use as Trade and Current Quote Symbol and have that field be blank. Refer to the following for the Use as Trade Only Symbol: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
