Date/Time: Sun, 28 Apr 2024 08:55:13 +0000
Testing various strategies with live data
View Count: 313
[2022-06-11 16:13:07] |
User887126 - Posts: 60 |
Hello SC Team, I searched through documentation and did not find clear solution to my question. I have several automated strategies with slight variation in each. i want to test all of them with live data using realistic fill and slippage. How can i test them simultaneously and get the statistics for each data? For example, if i have 10 different algo, i want to know the performance of each algo for a particular trading day. Currently, all the results are mixed into same sim account and i have to manually separate for different strategies. Is there an easier way? please advise. Thank you. |
[2022-06-13 13:54:37] |
If you are using the built-in Simulation mode, then you can have as many Simulation accounts as you want to be able to separate out the information by Sim account. Refer to the following information: Trade Simulation: Multiple Trade Simulation Accounts If you are using our Simulated Futures Trading Service, then you can create multiple accounts for that service and again, use a different account for each run to separate the information. Refer to the following: Simulated Futures Trading Service: Setup Instructions Another option is to tag the trades with one system versus another with a different "Note". Refer to the following: Basic Trading and the Trade Window: Set >> Text Tag For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
