Date/Time: Sun, 11 Oct 2026 16:50:29 +0000
Request on window-settings
View Count: 664
| [2022-06-09 05:52:27] |
| BrMa - Posts: 80 |
Dear SierraChart-Team, I would like to ask you for a small improvement (I'm currently on version 2394): The windows for the Trade Service Log and the Message Log do not store their window position and size and need to be put at the position wanted and resized after every restart. Besides that the window showing the Message Log resizes after every opening of a chartbook. May I ask you to store/restore window-positions and -sizes and do not change them on the opening of chartbooks for those two types of windows - just the same way as you do it for all the other windows? This would be great and highly appreciated! Many thanks in advance! |
| [2022-06-09 07:54:11] |
This is definitively untrue: The windows for the Trade Service Log and the Message Log do not store their window position and size and need to be put at the position wanted and resized after every restart.
The size and position are absolutely remembered and restored. This is not a Sierra Chart problem. The problem is with your operating system or drivers or whatever. Refer to: Window Size and Position Not Restored When Opening Chartbook This information also applies to the Message Logs. Why on earth would this functionality not exist for all of these years. It has existed, since the very beginning of Sierra Chart and it works properly. Once again the problem is with your operating system or drivers. One thing you could try to do is to use Window >> Reset Windows to reset the window placement data structures and perhaps that might solve the problem going forward. Maybe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-09 07:57:20
