Date/Time: Thu, 08 Oct 2026 15:08:19 +0000
Calculate Logarithm of Symbol?
View Count: 967
| [2022-06-08 08:36:57] |
| Techotomy - Posts: 104 |
Can you calculate the logarithm of a symbol? I see exponentiation is available in SC's list of arithmetic operators, but not it's inverse (Working with Spreadsheets: Arithmetic Operators). I also don't see the operator available in the list of Study Subgraphs. I would ideally like to compute log10 of Trin so that the positive and negative magnitudes are balanced. I could use a logarithmic scale on the subgraph, but I would also like to apply multiplication after logarithmic transformation (i.e., -100 * log(TRIN)).
| [2022-06-08 15:53:34] |
| John - SC Support - Posts: 48151 |
Both Natural Log and standard Log are available as functions in the Spreadsheet. Refer to the following: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#LN_Function For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
