Date/Time: Tue, 07 May 2024 23:10:35 +0000
Measuring Tool
View Count: 4578
[2014-05-01 18:23:30] |
User72443 - Posts: 1 |
Is there a tool available to measure ticks from point A to B?
[2014-05-01 19:20:48] |
VF56002 - Posts: 27 |
use "Chart Calculator" tool ... don't forget to configure it to display DIT - Difference in ticks
[2014-05-01 21:28:07] |
Use the Chart Calculator tool: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-14 06:11:55] |
User164231 - Posts: 278 |
Is there a tool to auto calculate the week's swing high and low value? Thanks.
[2019-04-12 20:40:03] |
tdug - Posts: 124 |
Is there a tool that can plot a proposed stop loss, entry and exit? I used it once and cant find it anymore.
[2019-04-14 03:06:08] |
Use this tool: Chart Drawing Tools: Reward/Risk Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-21 05:55:40] |
Hi my chart back ground is white and I believe the RR tool text is white as well. Where is the setting to change the text and line?
