Date/Time: Sun, 19 May 2024 07:24:01 +0000
[User Discussion] - SPREADSHEET FORMULA ERROR
View Count: 1062
[2014-04-30 16:47:07] |
enemyspy - Posts: 304 |
SC spreadhseets return the following error: "INDEX WAS OUTSIDE THE BOUNDS OF THE ARRAY" what does this mean? Formula: {=IF(F3=0,"",IF(AND($H3=1,$f3="A"),INDEX($A3:$A$404,MATCH(MIN(IF(h3:h$404=1,$D3:D$404)),$D3:$D$404,-1)),IF(AND($H3=1,$F3="B"),INDEX($A3:$A$404,MATCH(MAX(IF(H3:H$404=2,$D3:D$404)),$D3:$D$404,} I am using the above formula copy and pasted 97 times on top of itself in 1 each cell of a column. Everything is constant in all the duplicates of the formula except for the following statements: IF(AND($H3=1,$f3="A", IF(AND($H3=1,$f3="B", the $h3=1 on both counts up sequentially to $h3=97 with each copy and pasted instance of the formula. Anyone know what is causing this error or how I can fix the syntax? |
[2014-05-01 04:49:15] |
NEVER MIND I SCAPPED THIS APPROACH AND FOUND A DIFFERENT SOLUTION
[2014-05-01 06:01:35] |
OK. "INDEX WAS OUTSIDE THE BOUNDS OF THE ARRAY" means the following: In the case of the spreadsheet, and array would be a series of values. The first one in the series has an index of 0, assuming it is zero-based, and the last one has an index of the size of the array minus 1. So it is possible to reference any of the values within the array by using an integer index. As a general rule this error indicates that the index is less than zero or equal to the size or greater. However, what the exact indexes are in the particular formula you have, we do not know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-01 06:01:48
[2014-05-01 17:42:26] |
OK, thank you for this explanation. Now it makes sense. I think it might work if certain arrays are defined with more specific rules somehow. maybe i play with it more..thanks
