Date/Time: Tue, 17 Nov 2026 06:30:42 +0000
Currency Futures
View Count: 946
| [2022-05-24 20:58:50] |
| User606770 - Posts: 7 |
Can I view currency futures data with a basic membership? Thanks! |
| [2022-05-24 21:24:59] |
| John - SC Support - Posts: 48547 |
You can get the delayed streaming data for the all of the CME Group, including the currency futures. Along with data from EUREX, CFE, and NASDAQ TotalView. All that is required to get this data is any active Sierra Chart package (even Package 3 qualifies). Refer to the information here: Delayed Exchange Data Feed If you have to have real-time data, then you will need to be on Package 10 or higher. And also keep in mind the CME Group requirement that you have a live, funded, futures trading account to which you can connect your Sierra Chart software, in order to qualify for the non-professional exchange fees. Refer to the following for more information on this: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
