Date/Time: Fri, 04 Jul 2025 00:15:22 +0000
Change of service package, data to Denali data and order routing
View Count: 522
[2022-05-23 16:30:59] |
User982071 - Posts: 3 |
My subscription ended and I am looking to change to Service Package 11 - Advanced + Denali Data Feed or Service Package 12 - Advanced MBO + Denali Data Feed, but I want to know if these packages offer real-time data for simulated trading and live trading, currently I pay live data through my broker and CQG, so want to know if I do not have to pay through my broker for the CME data or if these packages only have the 10-minute delay data as the Service Package 5 - Advanced? Also if I would like to have my order routing through your service, how would that work, or what are the requirements? Is there any specific brokers you work for, you are becoming the broker or how do I set this up, and how does this work? Thanks |
[2022-05-23 17:00:00] |
John - SC Support - Posts: 40745 |
You would need to on Package 10 or higher and then go through the appropriate setup instructions for the exchanges for which you want the real-time data. As part of the setup, you will need to activate and pay for the exchange(s). Refer to the information at the following link, which also includes the Setup Instructions: Denali Exchange Data Feed Also if I would like to have my order routing through your service, how would that work, or what are the requirements? Is there any specific brokers you work for, you are becoming the broker or how do I set this up, and how does this work?
In order to use our Teton Order Routing Service you need to be with a broker that supports the service. The list of brokers is at Step #2 of Setup Instructions at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
