Date/Time: Sat, 12 Jul 2025 07:19:33 +0000
HIDE / UNHIDE DRAWING
View Count: 588
[2022-05-19 13:03:10] |
Mustang77 - Posts: 122 |
Hi If i draw something on the chart, for example a horizontal line or a rectangle, if i right click on the line and select "hide drawing", it hides the drawing, but, how do i unhide it so that it reapperas on the chart? Thanks |
[2022-05-19 15:51:59] |
John - SC Support - Posts: 40857 |
You need to use the Manage Chart Drawings window to show the drawing again. Refer to the following: Chart Drawing Tools: Manage Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-19 16:10:07] |
Full documentation about this is here: Chart Drawing Tools: Hide/Show Chart Drawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
