Date/Time: Fri, 04 Jul 2025 00:16:14 +0000
Where to put spreadsheet columns for background calculations?
View Count: 544
[2022-05-19 00:29:43] |
User14953 - Posts: 256 |
I have 8 spreadsheet columns that are not graphed which are used for background calculations required for my analysis method. They reside within columns K through Z. I want to free up this space. The sheet I just looked at is populated out to column GH. Where's the best place to relocate these 8 spreadsheet columns that are not graphed so they don't interfere with the Sierrachart Studies like Moving Averages, Pivots, etc.?? |
[2022-05-19 14:50:07] |
John - SC Support - Posts: 40745 |
The first thing we want to point out is that you have control over how many calculation columns there are and also where the study information will start in the spreadsheet, not to mention you can turn off whatever data you not want from studies going into the spreadsheet. Refer to the following to control the number of calculation columns: Spreadsheet Study Inputs: Number of Formula Columns Refer to the following to control where the study information is started: Spreadsheet Study Inputs: Blank Columns Before First Study And refer to the following for how to control whether a study's subgraph data is output to the spreadsheet: Chart Studies: Settings and Inputs Tab >> Include in Spreadsheet Given the above, you should be able to determine what works best for your situation in terms of moving things around in order to get room to place the columns of data you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-20 01:08:41] |
Thank you.
Date Time Of Last Edit: 2022-05-20 01:29:33
