Date/Time: Fri, 03 May 2024 03:00:02 +0000
I am having delayed data
View Count: 366
[2022-05-16 16:00:00] |
TradingInDemand - Posts: 15 |
I am using tenton order routing on ESM22_FUT_CME(M) through dorman and it's saying im having delayed data and im not sure why or how this happened
[2022-05-16 17:51:59] |
John - SC Support - Posts: 31334 |
Everything about your account looks good. We will need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
